wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-01-22T03:20:41+00:00
    I took mine back to the pop up store and they just replaced it, no questions asked, did all the updates, etc.  I dont think you will have a problem getting your money back, no need to sue!  I dont mean to say it;s not an awful problem...the tablet has such potential, but it is useless without WiFi.  Hope you get yours sorted out.  Mine works great now, I just never leave home with it.
