wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-01-21T18:56:25+00:00
    Updating yet again: since the Jan 15/16 update, wifi is better but still not great.  Now I only get the 'limited' problem when I change networks.  I can have my Surface connected at home for days and things are ok and consistent; however, if I take it to work, limited connectivity until I disconnect and reboot.  Once connected at work, it's fine for the day, until I go home, at which point it can't properly connected until I disconnect and restart.
    My AP at home is set to Auto/Prefer 40MHz, and at work there are multiples, generally set to Auto without preference. I have not applied the 40MHz reg hack to my surface (yet).
