wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-01-20T13:28:09+00:00
    I have the same "limited" connection problem, what i have found is it is particularly bad (loss of connectivity on averages a totally 5 hours a day) when i connect to a 802.11n connection (laptop wifi hotspot) I have seen a workaround online but this does not work, if anything it made the issue worse... the latest updates still did not make any solid difference, only that the length of online time has increased slightly, i have refreshed and restored my Surface to factory setting and the issue appears again and again after a few hours... im techo challenged. **** only
