wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-01-16T17:11:33+00:00
    Yes, this is a good and viable solution, you only need to apply the AutoUse40Mhz=0 portion if the registry hack. It seems some routers do not support this range and the Surface has issues recalibrating. Still needs fixing. But since turning it off. My WiFi connection has been solid at N speeds and u can connect to all APs I could not before.
