wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-01-16T02:37:57+00:00
    Following this thread, I've held off on applying the reg hack workaround.  If it comes to that, eventually
    I will apply it, but the speed hit is pretty lame. For now, restarting seems more tolerable.
    Bluetooth on/off makes no difference; airport mode toggle helps inconsistently; the only thing that is consistent is restarting.  I have also found that it's pretty solid once I'm connected to WiFi and don't take it out of range of the current access point.  Once I change AP's or networks, then the limited connection rears it's head and a restart is needed.
    Finally, I have noticed that once it's gone to limited connection mode, my restart feature on the menu always says "Update and Restart." At first I thought it was a patch revision or something on the 10th, but several times since then that "Update" label has reappeared, and only following a limited connectivity episode. I don't know why, but it appears to be connected.
