wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-01-15T21:53:37+00:00
    Just out of curiosity, has anyone tried modifying the Power Management of the network adapter - unchecking the 1st box "Allow the computer turn off this device to save power" seems to have worked for me and I don't lose connectivity. HOWEVER, this has created the Surface to lock up when going into Sleep mode and/or turning off the display.
