wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
  1. Barb Bowman 80,815 Reputation points MVP Volunteer Moderator
    2013-01-15T12:33:48+00:00
    historically, though, there have been some strange issues solved by turning off
    IPV6. I believe that ultimately these were driver related (Marvel Yukon Ethernet
    was afflicted with issues).
    http://social.technet.microsoft.com/Forums/en-US/w7itproperf/thread/4537c7b6-9761-41c5-8b47-0ecb831c8575/
    has some interesting history.
    but turning off IPV6 should NOT be a solution..
    Barb
    MVP - Windows Entertainment and Connected Home
    http://digitalmediaphile.com/
