wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-01-15T02:31:31+00:00
    No exactly. But I never applied the registry hack because choosing channel 4 is not correct if you want to be able to connect N.
    But like I was suspecting in the majority of the cases where you have a problem with the N forcing it to use the 20MHz is good enough. 40Mhz is faster but a lot more problematic. Now you are using N.
    I'm glad that this helped you.
    So far it has worked great!  Thanks for the advice.  I'm going to stress test it tonight.
    UPDATE: So I downloaded a few videos over my network, and listened to Xbox Music for awhile and it did go back to Limited Wi-Fi Connectivity.  It did seem to take longer to reach that point however.  Back to the drawing board.
