wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-01-15T00:43:52+00:00
    I used your suggestion today.  I'm sticking on 130mpbs with no limited crashes.  Is this what you have been using?
    No exactly. But I never applied the registry hack because choosing channel 4 is not correct if you want to be able to connect N.
    But like I was suspecting in the majority of the cases where you have a problem with the N forcing it to use the 20MHz is good enough. 40Mhz is faster but a lot more problematic. Now you are using N.
    I'm glad that this helped you.
