wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-01-15T00:28:08+00:00
    Greetings Everyone,
    @Barb, I'm doing some testing on my own personal time while the Product Team is investigating the WiFi issue, to see what the Surface will and wont play nicely with and see if we can get a decent work around. I believe you are correct, it should have nothing to do with IPv6 but I'll investigate that.
    @Surface007: Would be great to communicate when you fix the issue on this thread so we know to rollback the registry changes. We will let you know when we have a fix via Windows Update.
