wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-01-14T12:29:33+00:00
    Before the regedit changes to the autouse40mhz, my speed is 130mbps.
    After changing the values and switching to wireless b,g the speed is 54 mbps, quite an irritating change.
    Have you tried apply the registry hack but only the autouse40, do not apply the second one changing the channel.
