wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-01-14T09:37:58+00:00
    I have a very similar issue since the last round of Windows updates: I can see WiFi hotspots, but I cannot connect to any of them. At home, Surface RT did not connect automatically to my own WiFi as it did before and it took several retries to get a connection at all. If I manage to get a connection, it is "Limited", but after a few seconds I get a full Internet connection. It is massively annyoing that the device does not connect automatically any more.
    However, I am not sure whether the Problem is related to the Surface hardware or to Windows itself. I have upgraded my desktop machine from Windows 7 (which worked perfectly wrt. to WiFi) to Windows 8 and it took dozens of trials until I got WiFi on Windows 8. But since then, it seems to work quite reliably in contrast to my Surface which worked before and ceased working now.
    I have tried all from removing the networks, disabling the adapter, rebooting the machine, shutting down the machine, but for me, nothing worked so far. The so-called "registry hack" did not have any effect on my machine.
    Best regards,
    Christoph
