wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-01-14T04:36:02+00:00
    Before the regedit changes to the autouse40mhz, my speed is 130mbps.
    After changing the values and switching to wireless b,g the speed is 54 mbps, quite an irritating change.
