wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-01-13T23:22:07+00:00
    I have kept my Bluetooth off and constantly get the limited WiFi.  The only fix that has worked for me so far was the registry hack shutting n capability off
    Could you tell us at what speed are you connecting? Check your WiFi adaptor properties and you will see the speed there.
