wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-01-13T18:31:46+00:00
    Thanks a lot ! I'm giving this a try after a frustrating weekend where I tried to show off my Surface to my friends but only succeeded in embarrassing myself with the "Limited connection"  issue.
    @MSFT : would be great to communicate when you fix the issue on this thread so we know to rollback the registry changes.
