wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-01-12T14:10:51+00:00
    Turned Bluetooth off did a shutdown and then started back up and now the WiFi seems to be stable.
    Also while experiencing the WiFi limited connection issue my windows updates wouldn't work maybe related or not but glad my surface is ready when needed.
