wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-01-12T04:05:41+00:00
    Same problem here. I got my Surface Dec 25 2012, did the windows updates at the time, everything worked great. Starting Jan 8th, this precise problem began.  multiple networks, routers, access points. all other devices work fine but the surface has developed a nasty habit of only obtaining limited connectivity. I am a systems admin for a living so have a good bit of experience in troubleshooting this sort of thing - since it began, only reboots help.  I'm considering restoring to factory, but am hoping there's a fix of some kind since the last post here.
