wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-01-12T03:36:18+00:00
    Never had any issues until this week,  I took 7 updates and from that point on every time I go to use the surface and login it shows a limited connection.  I toggle WiFi disconnect and then connect.  Works until the next time I login and back to the same limited connection issue.
