wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-01-11T15:41:46+00:00
    I'd really like to know what the setup is on the router.  Do you have other devices connected to you home network?  Can you check why the wireless properties are?  WEP, WPA, WPA2, or any other.  Also, what is the encryption type used?  Any windows os that is connected will tell you that.  Also, is the SSID broadcasted?  Otherwise you will need to toggle the "Connect even if the SSID is not broadcasted" switch in windows.
