wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-01-11T15:24:30+00:00
    Check your event logs.  Check for any critical errors and post them here.
    No critical errors within the last 24 hours according to the event viewer.
    Problems were alright until last Tuesday's patch. Before that, I had the limited error, but it went away overnight. And now, this major error overnight.
