wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-01-11T13:20:13+00:00
    Have you rebooted yet?  Try that, then verify the IPV6 adapter is still unchecked.  If it is, next time it goes to limited, check the event logs for any critical errors.  The event logs usually will point us in the right direction.
