wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-01-11T12:24:11+00:00
    I cannot configure the router, no one knows the password to it.
    I tried the registry hack, I tried the netsh hack, and now I have refreshed the device. NOTHING. It won't make a single connection, nor even see my home network. To my phone, it connects with Limited while on a friend's phone it connects fully.
    I want my money back, whom do I call? I live in Sweden, but bought it in the US.
