wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2012-10-30T18:05:55+00:00
    I've experienced this as well and also have not had the chance to test other WiFi.  I'm using a Linksys\Cisco E4200.
    Crossing my fingers its a software problem that can be addressed in an update.
