wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-01-11T11:09:21+00:00
    The Surface cannot even see the home network anymore...
    Oh, and I should mention that at work, it connects just fine to the work router.
    Check that your home AP/Router in 2.4 Ghz band doesn't use Wi-Fi channels above 11. Surface (or I think even any Win RT device) does not support Wi-Fi channels other than US (1-11) in 2.4 Ghz band.
    Also I suggest you to try registry fix for now, till there is a real fix from MS.
