wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-01-11T10:00:19+00:00
    djlaney,
    I unchecked the ipv6 box in the settings as you described, but still hit the limited wifi issue again after 20 minutes of streaming video through amazon.  Is there something else I am missing?
