wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-01-11T09:49:12+00:00
    I've ran into this problem as well, after the updates on Tuesday 8th of Januari 2013. The Surface cannot even see the home network anymore... It's just lying at home now, no better than a coaster.. a very expensive coaster. And when I try to connect to my phone's Wi-Fi hotspot, it just goes into Limited mode. I am so very disappointed.
    Oh, and I should mention that at work, it connects just fine to the work router.
