wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-01-10T13:55:43+00:00
    Of course it shouldn't be required!!  There is some type of driver or adapter problem for the network interface.  Check the event logs, it points you right to the problem.  I'm not sure why no one else had discovered this yet, but that is what I found and it seemed to fix my issue as well as any event log error I was getting.
