wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-01-10T04:30:02+00:00
    The router-side change will eventually have to be reversed too, won't it?
    My brother-in-law would probably have given me his router password, so I could have done the router-side fix at his house when I was showing off my new Surface.  Starbucks, on the other hand, probably would not - and in all fairness to them, I probably wouldn't go back and re-set their router after this bug gets fixed, like I would my brother-in-law's.
    It's rare for people to "constantly roam around wireless networks," but it's very common for people to use more than one over the lifetime of their device.  I've used my Surface at home, at work, in coffee shops, bars, restaurants, and airports - there's only one of those places where I can "fix" the router settings.
    ...you don't consider using it at home, work, in coffee shops, bars, restaurants, and airports to be "roaming around"?
    a router setting can be changed with one dropdown and one button. aside from the fact that it simply takes more work to edit several registry keys, it's significantly easier for people who might not be so technically inclined.
