wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-01-09T21:45:13+00:00
    The registry hack is pointless for anyone who isn't constantly roaming around multiple wireless networks. If any device connected to an AP is on g it brings the entire network down to g, so if you're always connected to one wireless network, might as well just make the change router-side rather than messing with registry settings you'll eventually need to reverse at some point.
    The router-side change will eventually have to be reversed too, won't it?
    My brother-in-law would probably have given me his router password, so I could have done the router-side fix at his house when I was showing off my new Surface.  Starbucks, on the other hand, probably would not - and in all fairness to them, I probably wouldn't go back and re-set their router after this bug gets fixed, like I would my brother-in-law's.
    It's rare for people to "constantly roam around wireless networks," but it's very common for people to use more than one over the lifetime of their device.  I've used my Surface at home, at work, in coffee shops, bars, restaurants, and airports - there's only one of those places where I can "fix" the router settings.
