wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-01-09T19:31:38+00:00
    The registry hack is pointless for anyone who isn't constantly roaming around multiple wireless networks. If any device connected to an AP is on g it brings the entire network down to g, so if you're always connected to one wireless network, might as well just make the change router-side rather than messing with registry settings you'll eventually need to reverse at some point.
