wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-01-09T19:21:28+00:00
    All - A similar issue was posted here: http://answers.microsoft.com/en-us/surface/forum/surfwinrt-surfgetstart/surface-wont-turn-on/94524e7d-fd76-4dcf-b365-fa6fed6a49ec?page=4&tm=1357759117845.
    I was able to fix my issue by examining the event log to see what was causing the error.  In this case it was IPv6.  Weather that was a router issue, or a windows rt issue.  I am not sure.  I can tell you by disabling it (I don't use IPv6 at home), all my wifi problems went away.  check the link for more details.
