wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-01-09T04:06:07+00:00
    Nah, he earned it. He's a nice person and he did solve the problem for me.  I had absolutely no problem before connecting an iphone, laptop, netbook, and kindle fire to the work router... which was why I felt so frustrated that I could not get the Surface to connect.  My only issue with the Surface now is that it keeps restarting from sleep.... but I posted that on another thread....not a reason to return my Surface, as I can always shut it down.... just an irritant.  On the whole, I am enjoying the Surface very much....
