wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-01-09T03:40:33+00:00
    I tried the registry hack to change my router to a g and I'm still experiencing problems with limited connections.  So it seems that this quick fix isn't working for some people (i.e. me).  I think I will be taking my surface to a Microsoft shop and if they can't make a fix then I'll be returning it for an iPad.
