wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-01-09T03:31:45+00:00
    I almost returned my Surface because of the wifi issue.  I could connect at home, but not at work.  After several days of trying many of the workarounds on this forum, I was ready to give up.... but I loved the Surface so much that I finally asked our IT consultant (and paid him out my own pocket! as my issue was not work related) to look into it.  After about an hour of tinkering with it, he thought he found the answer but needed to verify.  The following day, he returned and it took him less than 10 minutes to fix the issue.  His fix:  the Surface can only connect to "Open" routers/networks (am not sure which).  Our system in the office was "Shared".  So he changed our system key to "Auto".  Voila!  I never had a problem again.  I just think it's weird that the Surface can only connect to "Open" systems.  Can Microsoft do an update that will allow the Surface to connect to "Shared" and "Open" systems?'
    Hope this helps someone. Am not tech savvy, but I thought I would share my experience for what it's worth.
