wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-01-09T01:44:06+00:00
    Mr.Misterioso - I would suggest not waiting until this problem is fixed to get a Surface.  While there are certainly a lot of people on this thread who are running into this problem, it is certainly not everyone who has a Surface.  I had some wireless issues early on (which is why I'm subscribed to this thread), but I believe in my case they were more about my wireless g router (which UVerse provides) being at capacity.  I bridged an N router to it and connected Surface to that, and wifi has worked fine since.  You can always get Surface, take it home, and if you have this issue, return it.
    It is important to keep in mind that all the people who have a Surface and who are *not* having wifi issues are not going to be commenting on this thread.
    (I have no affiliation with Microsoft).
    Eric
