wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-01-08T23:13:38+00:00
    Greetings,
    Sorry to hear that there wasn't a fix for the WiFi in the January update. To the best of our knowledge, the WiFi issue is still being looked at and is being addressed.
    Here are the Patch Notes for the January update (JasonMorton I know you posted in that thread already):
    http://answers.microsoft.com/en-us/surface/forum/surfwinrt-surfupdate/what-is-in-the-january-update-182013/506e79dd-7b77-47b6-8ca6-c9222a1b031d
