wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-01-08T23:02:11+00:00
    Thanks for giving me a shoulder to cry on Mr. Misterioso.  I have seen some of the workarounds but I am stubbornly operating off of the principal of it.  Besides this issue and the horrible xbox music app I do love my Surface.  It just enrages me that I can't use my 802.11n for what I bought the router for.  It is a great device otherwise.
