wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-01-08T22:34:24+00:00
    Well another patch Tuesday with no wifi fix in sight.  Applied the update hoping this would have a fix, began installing some apps from the store and bam, back to limited wifi.  I tried going in to the Microsoft Store, but they supposedly had no idea about this problem.  VERY FRUSTRATING MICROSOFT!  I am a huge supporter of your ecosystem, with my surface, windows phone, and windows 8 desktop, but I cannot recommend this device to anyone else.
    Hi Jason,
    I'm a prospective Surface RT customer and I can understand your concerns.  I've subscribed to this thread and have seen what is supposed to be a temporary fix on this forum here;
    "To lock Surface to 802.11 b/g band you can use 'Regedit'.
    Open Desktop -> Search -> regedit
    Open regedit. Select menu Edit -> Find...
    Enter "AutoUse40Mhz" -> do search.
    There are 2 such entries in registry. We need to change one, located under "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class" branch.
    Set "AutoUse40Mhz" to "0" (it has value "1" by default)
    Set "Band" to "4" (it has value "6" by default)
    Reboot and Surface will connect using 802.11 b/g band.
    Thanks, so far so good. Good temp fix. Thanks!"
    I hope this works for you but more importantly I hope MSFT comes up with a permanent fix and perhaps an explanation as to what's going on.  I too use Windows Phone 8 and recently downloaded Windows 8 on my desktop.  Love the ecosystem and would love to get the Surface when this bug is fixed; I hope someone is listening.
    Regards.
