wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-01-08T21:25:38+00:00
    Well another patch Tuesday with no wifi fix in sight.  Applied the update hoping this would have a fix, began installing some apps from the store and bam, back to limited wifi.  I tried going in to the Microsoft Store, but they supposedly had no idea about this problem.  VERY FRUSTRATING MICROSOFT!  I am a huge supporter of your ecosystem, with my surface, windows phone, and windows 8 desktop, but I cannot recommend this device to anyone else.
