wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-01-08T01:17:43+00:00
    We ended up resolving by going to the Microsoft Store and having them work on it.  Something about a  network adapter... sadly, I wasnt there so am not sure what they did exactly.  They said it was a 'setting' but for the life of me, I cant imagine what I didnt try.  Anyway, that finally worked.
