wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-01-03T22:54:36+00:00
    I really want this tablet to work but this WiFi issue that we are having at work is very frustrating.  All of our Surface RT's have the same problem (bought 10 to test), they do not hand off from one AP to the next very well at all.  (Enterprise wireless solution) Our office has about a dozen AP's and when you move out of range from one of them our Surface tablets refuse to pull from the nearest AP.  I can be standing underneath it and it will continue to show one bar from the previous connection.
    They will not roam properly.  We ran some diagnostics on the Wi-Fi side and the access points are seeing the roaming attempt and the Surface is actually roaming to the new access point but it doesn't update the signal strenght bars when this occurs.  It is also losing it's ARP cache when it roams and no longer has an entry for the default gateway which is why it is losing the connection and shows "Limited Connectivity"
    I can't express how frustrating this is.  This tablet has such huge possiblity as a bonified work tablet that has so much more potential than an iPad or Android tablet but this has to be fixed.  Please Microsoft fix these Wi-Fi issues or fix the hardware itself.
      PS - I've tried all the suggestions from previous posts (Thanks for all the info) but this hasn't helped.
