wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-01-03T19:13:33+00:00
    Hi, could you please give us the details of this fix? I think that this might help me in some cases.
    To lock Surface to 802.11 b/g band you can use 'Regedit'.
    Open Desktop -> Search -> regedit
    Open regedit. Select menu Edit -> Find...
    Enter "AutoUse40Mhz" -> do search.
    There are 2 such entries in registry. We need to change one, located under "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class" branch.
    Set "AutoUse40Mhz" to "0" (it has value "1" by default)
    Set "Band" to "4" (it has value "6" by default)
    Reboot and Surface will connect using 802.11 b/g band.
    Thanks, so far so good. Good temp fix. Thanks!
    I was ready to pull my hair out but this fix did it. I noticed the WiFi problem when I moved between my parents house and my apartment. My parents house has an old router that uses 802.11 b/g (if you hover over the white connection bar icon on the Surface that shows you what network you're on, it displays that info). In my apartment the router is newer and uses 802.11 n. I applied the fix above and lo and behold, the problem went away and I can use the Surface with my newer router!
    It's unfortunate that we have to resort to these registry changes but that's just how Microsoft works sometimes. I'm glad we have the ability to make these modifications. Thanks!
    P.S. I haven't noticed any differences with speed. I think the big differences between G and N are different from speed, like N has less interference from other signals and can transmit farther. Either way, hopefully Microsoft comes out with an actual fix soon.
