wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-01-03T18:20:56+00:00
    So earlier I stated that I could make my Surface connect to my home network and remain stable by pushing the push-to-connect button on my router. This remains the case, but I've been away for a couple of days and have not been able to get the device to connect to any network.
    I have followed the instructions for the registry hack with no success at all. I've also followed another recommendation re disabling and restarting the driver, but again I still get limited connection.
    So. Back to the drawing board. A shame, because this has the potential to be an amazing product, but right now, only able to connect at home, I might as well have bought a desktop...
    Mark.
