wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-01-03T16:56:37+00:00
    As i suspected the registry hack worked....
    with a Freebox V6 Router it worked
    with a IPhone Hotspot it worked too.....
    No more "limited connection" event after unused your Surface for several hours.
    Wifi immediatly works
    So for those who absolutely want to have no more wifi problems use the method registry described on previous posts on this topic  (AutoUse40Mhz)
    Etienne.
