wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-01-03T15:33:47+00:00
    The Surface uses a dual-band WiFi adapter.  Set the password, maximum data rates, and encryption on both of your router bands to the same values for both the 2.4 GHz and 5 GHz bands to avoid "limited" availability of your WiFi. Once you have done that forget the network and reconnect with the new password.
    To ensure a robust connection set the maximum data rate on both channels to the maximum dual band rate divided by the number of authorized devices on your network.
    When connecting to the WiFi network use the "push to connect"  feature to ensure that the security settings match those of the network.
    Change the password from the default on both bands and choose a strong password with reasonable entropy.
    Anyone tried this yet?  I don't own a Surface RT...yet.  Badly want one and would like to see some traction on this issue.  It'd be a shame for such a  cool device to be hobbled by a bug like this.
