wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-01-03T11:34:31+00:00
    And a happy new year 2013 without any solutions !!!!!!!
    It's been 2 months now ......
    • Tried the Windows updates patch (decembers patchs) : not working
    • Tried the command lines (netsh tcp ..... ) : not working
    I'm finally about to try the registry hack (disable N wifi for G wifi) but it's a shame !
    Hello Microsoft is there someone in this place ? Please provide a real normal FIX ! The registry fix can't be a solution !!!!!
