wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-01-02T02:41:48+00:00
    Well no luck with upping the router speed.  72 hours into the test and she received her first disconnect. This is Now back to a hardware / software issue directly within the surface.  I might try the registry hack next.
