wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-01-01T18:52:15+00:00
    marktharparms, I can assure you that switching off security is NOT a solution
    and pressing the button on the front of the router is also not a fix.
    Barb
    I wasn't suggesting switching off security was a solution - I was merely repeating what an MS chap said to me might be causing the issue...
    As for pushing the WPA button on my router - I'll go with that being a lucky coincidence, then, since my Surface has been working fine since I did it two or three days ago. And the network remains secure.
    Happy New Year
    Mark
