wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2012-12-31T19:33:01+00:00
    My wife is experiencing this same issue with her new surface RT.  It happens at least three to four times a day.  I just went into my router and changed it to broadcast over 802.1n only.  Now I'll need to wait until the rest of the family wakes up to see if I've bumped any other devices off the network.
    Hi Mike,
    I believe you will have more success if you set the router so it DOES NOT use 802.11n. Users have found it is this protocol that the Surface RT does not successfully work with.
    Bob,
      I have a NETGEAR router and my options are limited to going down to 54 mbps, 217 Mbps, or 450 Mbps.   There is no way to separate whether I am broadcasting on b/n or G.  Therefore, I selected the 450 Mbps which would imply the 802.11n connection.  So far so good.  All of my household devices are still working and the wife is watching for a disconnect.  I know it's more mental than anything else but I hate to think that I will need to dumb down my intranet capabilities to get the surface to work.
    For everyone out there, I'm now running 48 hours with no issues.  Again, I have a NETGEAR WNDR4500 (the 900 model).  The only change I made was inside the router where I changed the wireless setting to go "up to 450 Mbps".  All of my household devices still operate and my wifes surface has not disconnected.
