wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2012-12-31T09:57:56+00:00
    This might seem like a simpleton's answer, but: I was having issues with this too, as stated earlier. Contacted support and went through options with them but the issue remained.
    Not being a technical person I am not completely sure how to do registry fixes etc but was told by MS that the issue Surface is having is that it doesn't like 'very secure' networks.... I use a Devolo PowerLine adapter for my WiFi and you don't appear to be able to switch off security but, like many routers, it does have a WPA button on the front.
    I remember my wife's BlackBerry Playbook having a very similar issue and the solution was to press this button. I did so on this occasion too and now my Surface has been connected for over 24 hours without dropping the connection.
    It might seem a simplistic solution but it's worked for me; might be worth others trying if there's a security button on your routers?
    Mark
